reg93f150 Posted July 2, 2012 Report Posted July 2, 2012 i got a straight 6 4.9L i know this wont produce too much hp but just a little faster and sound a little better? any ideas? ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
certifiednut Posted July 2, 2012 Report Posted July 2, 2012 i have seen several with turbo kits, but not a tton of aftermarket parts out there for them. these orphans aren't going to feast on themselves
southern66ss Posted July 2, 2012 Report Posted July 2, 2012 i'm assuming you are talking about the ford 4.9? if so there are a good bit of parts out there for them, but start with the basics like header, exhaust, intake system, and chip. If that still isn't enough then look into higher compression pistons, cam, stroker crank. I know comp cams has a camshaft for it. I think eagle has a crankshaft. Go on a site like summitracing.com and see what you can find and afford. good luck and keep us posted b/c i haven't seen a 4.9 build up in a long long time. 2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp RE Audio SEX 12D4 Subs (12") Hifonics Brutus BRZ1200.1D NVX 4 gauge wiring NVX Deadner XS Power D925 Big 3 1/0 ga Q Power wire Custom box by Pro Audio Gulfport, MS 137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up
Jessica Posted July 10, 2012 Report Posted July 10, 2012 Is this a carburated or fuel injected? I guess this is in a f150 or f100 right? I had an f100 with a 300 (same engine) and i took out the 2.75 gear and put in a 3.5 gear. I used it to pull scrap iron (after i put in extra leaf springs). Pulled on the scale once with truck, trailer and scrap i weighed in at 11,900 the truck weighed 3200 empty. And I drove 70 up and down the hills and the truck had no problem at all. If I had the suspension i could have taken more easily. funny watching all the other trucks look at me funny as i passed them going up hills. LOL Oh, the point i am trying to make is check your gear ratio first. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ThwopKing Posted July 30, 2012 Report Posted July 30, 2012 You want performance from an engine made to pull massive loads at low rpm?..b e cheaper and easier to do a 5.0 or 5.8 swap. That engine was never made to rev high and put out lots of hp. Its a torque engine. It makes max hp at like 4200rpm....a custom header will cost you 500+,you will prolly have to make your own cold air intake so it would be cheap...as far as a chip forget it. Do a v8 swap if you want easy power. 2012 Toyota 4Runner Trail Edition-Singer 240A Alt, Odyssey Battery,Pioneer AVH-2550NEX head-unit, Pioneer GM-DX874 powering Kicker CSS67 front-CSC5 rear, and Memphis PR 1.1000 powering 12in SSA ICON in G.P. ported box. 2003 Tahoe-320A Alt, Odyssey Batt,2 Resilient Sounds Gold 15's sealed powered by Crescendo BC2000D, Turbulent Designs Ported box AVH601EX head unit and Pioneer 3ways in all doors.
reg93f150 Posted August 4, 2012 Author Report Posted August 4, 2012 yeah thats true, was thinkin about doin the 5.4 lightning swap into my truck, then in a year or so have the money for a whipple or kenbell supercharger to put on it and do some more little tricks, the way my truck is right now, no one in the world would expect anything out of it.. it'd be to funny haha any idea on how much a 5.4 lightning swap would be? ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Jessica Posted August 5, 2012 Report Posted August 5, 2012 What year is it? i would get a 351 windsor or 351 clevland, (not a 351m). Just drive your tuck for now with the 300ci because it will run forever. in the meantime build the 351 to a 383 stroker. It will be way better that a 302(5.0) and cheaper than a 5.4 lightning engine. Since the 300 you have will last forever you have plenty of time to build the 351. But like i said, don't get the 351-m, its just a 400 block and they suck. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ThwopKing Posted August 5, 2012 Report Posted August 5, 2012 Build a 351w...its cheaper than the cleveland and easier to bolt in. Also forget makin a 383 stroker,you would have t have parts custom machined as its not a very common sbf size...making a 408 is way more common hence being cheaper and readily available and will make more power. Find a 351w block...I prefer the non roller cam blocks than the later ,94-96, roller versions have been know to crack in the cam.bearing area when stroked and naking big power 2012 Toyota 4Runner Trail Edition-Singer 240A Alt, Odyssey Battery,Pioneer AVH-2550NEX head-unit, Pioneer GM-DX874 powering Kicker CSS67 front-CSC5 rear, and Memphis PR 1.1000 powering 12in SSA ICON in G.P. ported box. 2003 Tahoe-320A Alt, Odyssey Batt,2 Resilient Sounds Gold 15's sealed powered by Crescendo BC2000D, Turbulent Designs Ported box AVH601EX head unit and Pioneer 3ways in all doors.
b-dubs89 Posted August 20, 2012 Report Posted August 20, 2012 which year truck/engine are you talking . not as many parts for the ford big 6 but still some out there . back in the day a freind of mine had a fuel injected big six and it would hall ass bone stock , one day he was burning the tires so hard it jumped out of gear . port matching , polishing . work on the head and the intake .engine balance . i say go for it
reg93f150 Posted August 23, 2012 Author Report Posted August 23, 2012 its a 93 300 L6, fuel injected.. but ive been thinkin and thinkin im probably gonna end up doin the 4wd conversion in it, and maybe doin a 351W conversion and doin the heads n pistons n everything like yall have been sayin im just wonderin how much it would all cost for a 4wd conversion, axles, tranny, computer, and the bone stock 351.. damn im about to cry just typin all that haha, gotta spend some money to play with the big boys though haha ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
