Tseng2394 Posted July 4, 2012 Report Posted July 4, 2012 Today I was on my typical cruise from the city. Suddenly the sound from the subs cut off so I pull over. The amp power was still on and stayed on but still no sound from the subs. What's the problem here? connections from back to front seem to be fine. i don't have a ddm so i came to you guyd Amp is a p1000/1 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Guest Posted July 4, 2012 Report Posted July 4, 2012 unhook subs from amp. take a 9v and put + wire on + battery terminal. - on - obviously too. if subs move, then they may be okay. if they dont move at all, check for a loose wire inside the box
Riley Evan Houser Posted July 5, 2012 Report Posted July 5, 2012 Not sure what type of subs you have.. But I used to have 2 15" Kicker Comps and sometimes the sound would cut off so I'd check all my wiring..my amps and everything.. But couldn't find the problem. So I decided the take the nonworking sub out of the box and sure as shit, the banana plug on the sub came unscrewed.. Happened twice before I replaced them with a different sub I had prior
carshateme Posted July 5, 2012 Report Posted July 5, 2012 Also check your RCA cables, if none of the above solved your problem. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
bassface Posted July 5, 2012 Report Posted July 5, 2012 first determine if the subs are not working or the amp is not working then backtrack from there.
