Need Help With Alt/wiring Please
Hello everyone, this will be my first post here...been lurkin for awhile though...im having trouble with my install, seeing how it is my first install/system ever. Im going to be putting a 15" Fi Q on a T1000bd in my 01 taurus..i have a 4 awg memphis wiring kit with a 200A inline fuse, and plan on doing the big 3 with the left over 4awg. on CA.com and ROE they said that the 200 might be a little large of a fuse, and i should just get both fuses (for amp/batt and big 3) that is equal to my alt's output.
my question is, if this 200A fuse is too large, what fuses should i go with? also, how would i figure out what my alt puts out??
thanks!,
emd
200a is too much current for 4ga wire.
150 amp fuse is required. the fuse that sits inside of the rf t1001bd is a 150 amp fuse, so that is what you should be running. i ran a 150 amp breaker with my old rf t1k and i was fine. hope this helps.
A minimum of 2awg wire is what RF recommends for that amp. 1/0awg wire will be better. You always fuse the wire depending on its rating. 4awg wire is good for 1000watts & 100amps of current meaning it would need a 100amp fuse. That amplifier requires a 150amp fuse which is why you need at least 2awg wire which is also rated for 150amps of current. If you plan on using any other amps such as a 2 or 4ch for your front stage then you'll need bigger 1/0 wire to adequately power that as well.
  • Who's Online   0 Members, 0 Anonymous, 3902 Guests (See full list)
