ray the only focal plug and play stuff i can find is specifically made for the peugot 207. link to what you're talking about?
this is recommended from crutchfield for use with an external amplifier. im not too knowledgeable about the balanced inputs stuff
http://www.crutchfie...PAC-SOEM-4.html
i'd use this if no external amp is needed?
http://www.crutchfie...ss.html?tp=2977
and then these are the speaker mounts you're talking about wicks?
http://www.crutchfie...ts.html?tp=2824
Try to find an LOC that says it accepts "balanced" or "differential" high level inputs just to be safe.
Yep, that's the mounting bracket. Comes with HW and has many mounting tabs for various speakers.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Not from me, I don't have any experience with LOC's other than the cheapy $20 ones and I didn't like them at all.
After that I've always just installed an aftermarket HU.
I have seen Ray recommend this to another person installing in a Bimmer:
http://www.arcaudio.com/product-pages/processors/oem/sri.asp
Probly pricier then what you're looking for though.
In the manual it states that it has 6 balanced high impedance inputs though which is what you'd want.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
but i HAVE to use a balanced line converter/driver?
Hard to say...depends on the balanced output.
Some "light" reading :blink:
http://en.wikipedia..../Balanced_audio
http://mikeriversaud...ced_revised.pdf
Some you can mix, some you can't.
It may work but you could potentially damage your HU outputs. You could also get a reduced output from the HU since you're only using half the signal.
Personally I'd play it safe. When used correctly balanced outputs are great for noise.
I did a lot of research on mine and there isn't much detail out there about the Harmon Kardon HUs.
I wanted to stick with my factory HU and add something like a Fosgate 360 to integrate it to my amps.
After not finding much (and getting sick of the factory HU features and sound) I just pulled the trigger on an aftermarket HU.
Of course you could just tap off of the speaker wires after the amps. Those are unbalanced, but noisier.... :shrug:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Geeezuz,...
I can not believe how much this line driver has come up lately. Like its laughin at me.
Kranny,
I don't know exactly what your attempting to do. But, speaking on the unit itself, I LOVED this product. Was by far the best "LOC" I've ever seen or used,....
And again, I sold mine to Trey, and, wished I hadnt. Also, it didnt introduce ANY unwanted noise, and in fact removed a slight hum.
And like your seeing, it can "up" the line voltage like a mother..... Optional balanced or UN-balanced switch, clip light is just a bonus... Great unit..
Harness
Antenna adapter
Dash kit
Look up focal for speaker replacement.
They just came out with a diy spkr kit.
Kinda cool for you guys that like to diy.
As for the wheel controls
Needs a metra aswc for that car i believe.
http://www.crutchfield.com/p_091IS130/Focal-Integration-IS-130.html?tp=106 these ray?
team chat assholes ftmfcsw
skittlesRgood[/color]' timestamp='1337803095' post='2027302']
go for it. 1st off, you couldnt get past the gate. second, i wouldnt even hear your system inside my house. third, i would just turn mine up and drown out your system, eat my skittles, and laugh at your pathetic ass.
well he just bought a an alpine cde-hd137bt and wants to use the HK amp, so im still kinda clueless on how to go about this
edit: $500 budget for interior speakers
Edited by Kranny
could this work? says unbalanced and balanced mode
http://www.sonicelec...ate-RF-BLD.html
edit: but then in balanced mode, it outputs 22v to the rca's. thats a shit ton
Yep, that should work fine.
With a balanced signal, the negative portion moves opposite to the positive so you have twice the voltage swing.
Depending on your amp(s) you'd most likely use the unbalanced mode on the output (11Vrms) and use the gain to adjust it correctly to the amp.
If your amp(s) support balanced signals then by all means use that and get more noise rejection!
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
