So, I'm doing a new build once I get a hold of a new car.
This is what I will be using in my new build.
Kenwood headunit of some sort.
Rockford 6.5" P1652-2 component - have
Rockford 5x7" P1572 component - have
Rockford R300-4 amp for components - need
Ascendant Audio SMD series 15" DVC 2 ohm - need
Now, it comes to the question: What amp should I use?
I pondered about getting a hold of a Rockford T4000.1db, but I couldn't find one.
Which amp should I be using for the SMD 15"?
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
Audioque 3500D.1 is a good amp as well as all the ones stated above.
edit:
Sundown SAZ 3500D.1
http://store.soundso...-saz-3500d.html
Crescendo Audio 3500D
http://store.soundso...-amplifier.html
AudioQue 3500D.1
http://www.audioque....ifier_p_32.html
but if you dont have the electrical to back it up it could end badly... just saying I didnt see anything about electrical above.
Edited by Relyks
Yes, I plan on wiring it down to 1 ohm.
Thank you for the suggestions, I appreciate it.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
I think I am going to go with the Crescendo Audio BC3500D. It seems to be the best budget amp.
Thanks again guys!
Relyks, I am thinking about running, possibly, (2) Optima yellow tops.
Any other suggestions would be in consideration.
Edited by Joshex
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
Thanks again guys!
the batterys wont be enough. , at least not imo i say check out irraqi /dc power H/O alternators
( just adding them batteries will add a strain to your alternator specially if it is the stock alt. which therefor will equal not full power and strain on the amp which could cause it to overheat and burn up )
so like i said above my suggestion would be a high output alternator and lots of grounds ( can never have to many ) along with the 2 batteries.
edit: also big 3 if you havent already.
Edited by Relyks
If you happen to stumble across a t4000 you will def. need a high output alt and batteries to be on the safe side. When you go big, you have to pay. Just found all this out myself. Good luck with your build.
I would buy an AQ3500d.1 can be found used for $600 shipped which is great bang for the buck. But you need to think of electrical first. You will need at least a 200+ amp alternator and a nice 100AH battery. The electrical you need will cost more than the amp.
Edited by andale927
I would but an AQ3500d.1 can be found used for $600 shipped which is great bang for the buck. But you need to think of electrical first. You will need at least a 200+ amp alternator and a nice 100AH battery. The electrical you need will cost more than the amp.
X2
