Using Audition 3.0, adding in my own bass line to a song with sine waves.
I have always gone through and made sure the waves intersect each-other at 0, but this is starting to get really old when doing a song with a lot of notes.
Is there a better way to do this?
Fade in and out its about all you can do from what I know. could be other methods tho.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
This is normally what I do, but as I said: It's fairly time consuming to do that to each change in frequency
Zoom in so can see a smooth waveform and then select the entire first wave... go to Effects... select Fade In for the beginning of the wave and Fade Out on the end.
That or if you use them frequancy alot... just save it as a project and load it.. then copy and paste it in.
  • Who's Online   0 Members, 0 Anonymous, 635 Guests (See full list)
