pioneerpoundingspl Posted July 10, 2012 Report Posted July 10, 2012 Alright so I have a yellow top under the hood and am running roughly 3000rms, my voltage is terrible and drops down to 12 volts if im not carefull. There is a 240amp rebuilt alt under the hood and 0 gauge throughout. I came across a extra battery laying around and am curiouse if you can run it with the yellow top in parallel. The battery is a Interstate Marine/rv deep cycle battery here are some specs. Pretty well just wanna know if this would be worth setting up. Thanks Interstate SRM-27 Deep Cycle Marine & RV Battery 600 CCA Chemistry Conventional (Wet Cell) Voltage 12.0 V Capacity 96 Ah Rating 1152 Whr CCA 600 Cell 6 cells Connector Marine 134db
95legwagon Posted July 10, 2012 Report Posted July 10, 2012 i always seen on the net that your not supposed to run wet cell with agm batteries...... not too sure why or if its true but i would avoid it until you know for sure. have you done the big 3? maybe try selling that battery and buying another yellow top.....there not that expensive i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
pioneerpoundingspl Posted July 10, 2012 Author Report Posted July 10, 2012 Alright thanks for the help ye ill probally just try to get ahold of another yellow top. and yes i have done big 3 134db
bassface Posted July 10, 2012 Report Posted July 10, 2012 Yeah you can still run it, wont work as well but will still work. 95legwagon was referring to resting voltage of the batterys, the agm will have a higher resting voltage and will continually drain the other battery, possibly shortening the life of the higher resting battery. I would honestly think a clock or alarm would do the same thing, but i could be wrong.
