I just purchased a sa10 sub from woofersect. com. i should have it on friday . looking to biuld a sealed enclosure for it. in the specs on the site it says .5 cubic foot for the enclosure. my question is does that include the displacement of the sub? some manufactures include it. some you need to add it. i was also wondering with such a small enclosure is polyfil required.
It 0.5cuft net so your box will have to be 0.6cuft gross,
I wouldn't use Polly fill
Do you have the space to port it?
i do hsve space to port it. i have a 02 2dr blazer. just trying to go more towards sound quality and compactness. i usually run 12's ported.. the problem for me with ported is i listen such a large variation in music. lot of hip-hop, metal, classic rock, some trance/electonic .
So do i, and i run 2 12s ported, had them in my blazer and now my lancer. The subs do the job on everything, but my mids cant always keep up and blend that well...I listen to a LOT of electronic music, downtempo, trip hop, trance, hardstyle.
10"s are prob a good choise, but idd graph it for the flatest response,
I'm not at home now but someone should be able to do it for you, if you have enough space
Try a T-line on ported box at 25-28hz maybe even 30flat
It will louder the sealed and play everything
But you will need some 6x9 or similar to take over from 70-100 and up
I've seen a sa12 ported at 22hz and it played up to 60-70hz at a fairly even level( never saw it on a termlab) but is sounded good, did go as loud as I tought for mid 400 rms but was clean
Edited by john253a
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
