With them all wired together whats the final load?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Posted (edited)
if they're 4 ohm woofers
you can either wire them to a 4ohm load or 1 ohm
e/: if they're 8ohm woofers, they can be wired to 2 ohms
Edited by Robby Holmes
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Posted (edited)
Those look eerily like the w3013ps subs they make but with a slightly different cone(<-edit). I mean the specs are almost identical. Hmm, I'm going to bet your best bet is either give them 2cuft each and tune really low or put them in a sealed box. Since they are so similar i would say they would probably do better sealed. Wire to 1ohm and put them on a skar1500.1 if they die just get something better.
Edited by strangeduck
Posted (edited)
i recommend having them wired like this
edit: what is your budget for an amp around 1600w?
Edited by Kranny
A 1500 watt amp of a quality brand such as Dc 1.5k, Skar 1500, sundown 1500 etc all do more than 1500 at 1 ohm
dc doesnt make a 1.5k. and your sig is long as fuck lol
try an 1800 watt kenwood
not the greatest brand, but i had 2 12" Alpine Type E's on it and it was totally fine
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
