So i am strengthing my electrical system and need some knowledge. I have an aq 3500.1 at .5 ohms. I am picking up a d3400 under my hood tonight. I also have a singer 250 alt and all 1/0. I know i need battery (s) in back but how many and which size. Also whats the equations to figure out how big alt you need and how much battery amps you need ?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Lookig to see if i have enoygh alternator power and how muh battery power i need. I kniw HHR Ed has some equations not sure im mobile now so ill look when i get home
http://www.supercirc...-Amps-Converter
Edit: Is this what you're looking for? 12v x 250 amps = 3000 watts?
500 watts are left over. We need to divide that by 12 volts and that will give us about 42 amps.
If you have, lets say, an XS D3100 battery that has an amp hour rating of 110, your battery will
last about two and a half hours, in theory. The harder you run your batteries, the less you'll see
in a real life application. If you have a 110 amp hour battery, and you're pulling 5 amps from it, you'll
probably see 110 amp hours from the battery. If you're pulling 90 amps from a 110 amp battery, you won't
get over an hour of time, because it's being pushed so hard. It might only give you half an hour of time.
I have a thread in the XS power forum asking for these exact numbers for a D3100 but I'm still waiting for an
answer, after 5 days. I'm just a newb, so someone please correct me if I'm wrong.
OP, I'm only figuring in 3500 watts of power for your amp (I don't even really know what it's putting out).
EDIT: To clarify amp hours
Edited by Born_Again
you need to know how efficient that aq is at .5 ohm
14volts x 250 amps = 3500 watts
but that aq is prb only 50-60 % efficient at .5 ohm so your back down to around 1800 watts
so 1800 watts / 12 volts, since your alt isn't keeping up we will say 12, plus its always better to have extra
so 1800/12=150 amps you need to make up with batteries
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
more or less
watts=volts x amps
Amp efficiency means how many of those amps the amp can actually turn into watts
pioneer h/u
1 XS d925
1 Stinger spv35
OK, you lost me. How is his alt not keeping up? His alt will provide 3000 watts.
but his amp doesn't see watts, it sees amps
and an amp has to work to turn those amps into watts
and no amp is 100% efficient and when you lower the ohm you lower your efficiency so if you work your way down to .5 ohm your really running inefficient
idk the efficiency of that aq amp but i'm sure its quite good, 50-60% is just a low number to keep his voltage up.
pioneer h/u
1 XS d925
1 Stinger spv35
OK, so the amp is pulling 3500 watts, but actually converting maybe 2000 watts of it?
But it's using 290 amps? Or is the inefficency making it pull only 180 or something amps?
Either way, I don't see how there is a loss of 100+ amps figuring in only this amp, or am I missing something?
I'm not arguing with you, I just want to understand. Thanks dude.
