Anyone have issues with mb quart onxy amp turning off if the voltage drops below 12.5v? i am running 2 onx4.80 and one onx1.1500. i have 270 amp alt. 2 batteries one dieheart palt. group 34 in the front and one deka Group 31DTMAGM in the back. i have two runs of 2 gauge each neg. and pos. from front to back.
Idk, i have the BRZ1700, which is the same thing IIRC (or close enough) and mine did that a few times till it went into protect permanently and i had to send it back. Im ASSUMING its voltage drop, IT said it was a short on the board when i called them, so I'm assuming it was caused by low voltage. Are all your connections tight? Sounds like with your electrical your voltage should drop at all let alone to 12.5, i only drop to 12.9 at idle with just a HC1400 under the hood and no big 3, just 1 run of 1/0 for my positive power cable.
is there a such thing as too many grounds? can i add extra ground maybe thats an issues. all my connections are tight. and i sit at 13.9 at ilde with nothing playing.
if all the grounds have different potentials, yes, you can have too many grounds. But as long as everything is grounded to the same spot, it shouldn't be an issue. I don't know that the grounds are your issue, is your alt doing what its supposed to? Are your batteries holding their charge? I can't believe that amp strains your system that much harder than mine. Sure, I'm running at 2 ohms, but i ONLY have a STOCK 120A alt, and HC1400 under my hood, thats all my electrical consists of. The weekend after the one coming up I'm ordering my shit for the big 3 finally. So i don't even have that done. Sounds like you definitely have some sort of problem. have you tried a different amp?
Did you do big 3?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Did you do big 3?
everything is run in two gauge. yeah i had this issue before that's why i got the deka battery. i have meters @ the main battery the second battery and the distro box.
are you playing full tilt at idle
even if he wore, he drops worse than i do...and his electrical is much better than mine...in theory....test your batteries, make sure they are holding a charge. Make sure your alt is doing its job...thats all i can really think of....check all your connections...it sounds like you got a bad connection somewhere, i mean, i don't see why your system drops worse than mine, i get down to 12.9 at full tilt at idle.
  • Who's Online   0 Members, 0 Anonymous, 1916 Guests (See full list)
