I have a 2002 mustang I want to have a ported box with the dims 35"w x 11"h x 24"L. I want to have 2 sa 10s I will be using a 1700 hifonics. Can someone design a box for me? I want the best SPL possible since the trunk is so small. The reason the box is so small is I want to be able to slide the box in from the backseats.
Your dims would need to be wider and/or to taller to fit 3 10". In a Mustang you should have more than 10"H.
Edited by Joe X
He want it for 2 10's. And oh @Joe, the box you designed for me slams thanks.
Right! damn, he was requesting a 3 sub box in another thread. Glad the box did it for you, BTW clean and solid build you did, checked your thread.
Edited by Joe X
Ok here is a suggestion within your dims for 2 SA-10 ported:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 2.6 ft^3
External Height = 11 in
External Width = 35 in
External Depth = 20 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 35 x 11
Left & Right Sides = 18 1/2 x 9 1/2
Top & Bottom = 35 x 18 1/2
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 9 1/2
Extension = 6 x 9 1/2
Assembly guide (generic dimensions):
Thanks 4 the help. I will probably go with that box since it will be the cleanest an best fit fe the trunk. My only fear is are two 10s going to be loud enough? I plan on having like 1200-1700 watt hifonics. How many watts should I use?
You can give them the full power of the amp (Sundowns are underrated) given that your electrical is adequate and that you make use of the subsonic filter. But as I pointed out previously if you wire 3 sa8v2 subs you are not going to be able to match the optimal impedance of one ohm and that will cost you output but with 2 10" you can wiring everything in parallel (dual 4 ohm).
Now if you can provide 2200 [email protected] ohm at the 3 8" (maybe with a 2.5KW amp) then you may get some more output from that setup but it will be more expensive to do.
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
