rfaudiomustang Posted July 12, 2012 Report Posted July 12, 2012 So figured that I should probably start a build log up of this as it is going to be a rather large build. It's going to take a while to finish but I'll keep it updated with pictures as much as possible as it progresses. Here's The Build: -ROCKFORD FOSGATE- 8 - P3D212's 4 - Punch Pro 8's 4 - T1 Tweeters 4 - T1 6.75" Coaxial's 2 - T2500-1bdCP's 2 - T600-4's 1 - 3SIXTY.3 2 - 51ft Spools 1/0awg Power Wire 6 - 15ft Spools of 12awg Speaker Wire 2 - 30ft Spools of 16awg Speaker Wire 8 - 16ft RCA's 4 - 6ft RCA's 4 - 3ft RCA's 4 - 200A Circuit Breakers 6 - 500A ANL Fuses 6 - 300A ANL Fuses 6 - 200A ANL Fuses 20 - 1/0 Gauge Ring Terminals 40 - 4 Gauge Ring Terminals - Other - 2 - VMAX Charge Tank 2500 Batteries 1 - Optima Yellow Top 1 - Custom 300A Alt made by Nate at Excessive Amperage I'm hoping that this will play out the way I have it in my head. Should be pretty damn loud. I'll post some pics in a bit of what I have done now. Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
ch0sen Posted July 12, 2012 Report Posted July 12, 2012 you'll prb need some pics of atleast the car if you want to get ppl following along My current 95 Jetta Build w/ pioneer h/u 2 RD Sonance 10's with flatwind coils 2 Audiopipe apsm 1500.1s 1 Hifonics Brutus Elite 60x4 1 XS d925 1 Stinger spv35 1 1000 amp lead acid 50 ft of 0/1 ofc from Audiotechnix all powerbass components, and coaxils, 4 sets buildlog = http://www.stevemead...2-rd-10s-build/ My build for my wife. http://www.stevemead...01-f-150-build/
OrionStang Posted July 12, 2012 Report Posted July 12, 2012 How much of this gear do you already have? Your title says 12's, your parts list says 10's. What year Mustang? SMD Super Seller My Feedback Thread
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 Currently uploading... hang on Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 I had a build with P210's. Starting a new build. I already have everything on hand waiting to go in Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
OrionStang Posted July 12, 2012 Report Posted July 12, 2012 Whats the orientation of the box design? SMD Super Seller My Feedback Thread
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 Old system: Here's pictures from the teardown of the old system: Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 Thought it'd be a good idea to have a comparison of starting weight vs weight when this build is done. Here are pics of the scale with the old system out and all interior panels in. With me in the car: Without me: Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 Here are pics from the weekend of deadening the car. I meant to start this build log then but ended up just being too busy. Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
rfaudiomustang Posted July 12, 2012 Author Report Posted July 12, 2012 Oh, just came across these old pics as well. Figured I'd post them up too! Build In Progress! 2000 V6 Mustang H/U - JVC KW-ADV64BT 8 - P3D212's / 14cu. ft. / 34hz Front - T1675x2, PPS4-8x4, T1TSx4 Rear - T1675x2, T165x2 Sub Amps - T2500-1bdCPx2 Mids/Highs Amps - T600-4x2 3SIXTY.3 Signal Processor 51Ft. RF 1/0 Spool x 2 Excessive Amperage 300amp Alternator VMAX CT2500 x 2 Optima Yellowtop
