3 12" box
I am going to run 3 earthquake dbxi 12's. The manual says anything from 1.5 to 2.5 cubes, so it is throwing me off. I have 1200w rms to give them. This is a daily driver non burp setup. My max dimensions are 14h x 37w x 36d. I wanted this thing to get low since I have never had a box tuned under 37ish. Any help would be great, if you need any more info let me know.
thats literally perfect for those subs. a little under 3 cubes per sub with those dimensions.
im personally a Aeroport guy, so my set up is just a plain box(with internal bracing of course) with a 6" aeroport tuned to ~31Hz.
it sounds great.
i run both of mine in a single chamber(it saves space) and just have the port between the 2 subs.
aero's are also great because of how easy it is to tune them. just just a little plastic here or there.
slot ports, if you want to change the tuning, you have to take the box apart or build a new one.
that's my opinion
if i do it like that will it not choke the port? and i will be using aero ports
i dont exactly know what you mean by choking? but i have had amazing results with where it is right now anyways.
Yes! aeroports ftw
  • Who's Online   0 Members, 0 Anonymous, 426 Guests (See full list)
