Jessica Posted July 14, 2012 Report Posted July 14, 2012 Just curious, If you put a volt meter on an amp without speakers hooked up, what do you assume the ohm load is? I ask because I put my volt meter on my 4 channel today and was getting 25.1v with the clipping light just starting to flash slightly, soft clip with the 0db tone. I hooked a speaker up and it dropped to 24.8v The speakers read 3ohms. I am guessing that's between 150 and 203 watts. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Wicks Posted July 15, 2012 Report Posted July 15, 2012 Just curious, If you put a volt meter on an amp without speakers hooked up, what do you assume the ohm load is? I ask because I put my volt meter on my 4 channel today and was getting 25.1v with the clipping light just starting to flash slightly, soft clip with the 0db tone. I hooked a speaker up and it dropped to 24.8v The speakers read 3ohms. I am guessing that's between 150 and 203 watts. An amp with no speakers connected has an infinite load (Mega-ohm range). Your voltage dipped when you added speakers because of the lower resistance load and the internal resistance of the amp. Theoretically, 24.8Vrms at 3ohms would give 205W (V*V/R) BUT speakers have varying loads with frequency so it would depend on what frequency you played and what the resulting actual load the speaker would give... LOTS of variables. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted July 15, 2012 Report Posted July 15, 2012 Like what wicks said. Lots of things to consider, lots of variables. In theory, it might give you some sort of a general idea, but... See my sig ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jessica Posted July 15, 2012 Author Report Posted July 15, 2012 Just curious, If you put a volt meter on an amp without speakers hooked up, what do you assume the ohm load is? I ask because I put my volt meter on my 4 channel today and was getting 25.1v with the clipping light just starting to flash slightly, soft clip with the 0db tone. I hooked a speaker up and it dropped to 24.8v The speakers read 3ohms. I am guessing that's between 150 and 203 watts. An amp with no speakers connected has an infinite load (Mega-ohm range). Your voltage dipped when you added speakers because of the lower resistance load and the internal resistance of the amp. Theoretically, 24.8Vrms at 3ohms would give 205W (V*V/R) BUT speakers have varying loads with frequency so it would depend on what frequency you played and what the resulting actual load the speaker would give... LOTS of variables. Well, I understand impedance rise and all that. But shouldn't a lower load give higher voltage? Or does it only effect amperage. I know that (Volts X Volts) / Impedance = Wattage. Wouldn't high resistance give lower voltage? Or does it effect only amperage. I figured in a 4ohm load for rise to get the 150 watt as the lowball number, but that's just a guess of course since I can't prove it without a clamp meter. Anyway, thanks for the reply. edit, Why did i ask that twice? Proofread duck, Proofread. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Wicks Posted July 15, 2012 Report Posted July 15, 2012 Just curious, If you put a volt meter on an amp without speakers hooked up, what do you assume the ohm load is? I ask because I put my volt meter on my 4 channel today and was getting 25.1v with the clipping light just starting to flash slightly, soft clip with the 0db tone. I hooked a speaker up and it dropped to 24.8v The speakers read 3ohms. I am guessing that's between 150 and 203 watts. An amp with no speakers connected has an infinite load (Mega-ohm range). Your voltage dipped when you added speakers because of the lower resistance load and the internal resistance of the amp. Theoretically, 24.8Vrms at 3ohms would give 205W (V*V/R) BUT speakers have varying loads with frequency so it would depend on what frequency you played and what the resulting actual load the speaker would give... LOTS of variables. Well, I understand impedance rise and all that. But shouldn't a lower load give higher voltage? Or does it only effect amperage. I know that (Volts X Volts) / Impedance = Wattage. Wouldn't high resistance give lower voltage? Or does it effect only amperage. I figured in a 4ohm load for rise to get the 150 watt as the lowball number, but that's just a guess of course since I can't prove it without a clamp meter. Anyway, thanks for the reply. edit, Why did i ask that twice? Proofread duck, Proofread. When you measure the voltage on your amp output terminals with no load attached, you're looking at the actual voltage on the power rails. When you start to draw current the internal resistance in the amp will reduce the output voltage. If you have a "lesser" power supply in the amp it may also droop as it i can't maintain the power rails. A perfect amp will have zero internal losses and an infinite current supply so it wouldn't droop. Think about this: You said that a lower load might give a higher voltage... Take that to the extreme and lower the load all the way to zero ohms (dead short). V=I*R=I*0=0Volts. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Jessica Posted July 15, 2012 Author Report Posted July 15, 2012 OK, that makes sense, I guess i will clamp when i can, It's not a big deal i'm just curious what i am sending to my mids just to satisfy my own curiosity. I just one of those people that want to know exactly what everything in my car is doing. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
