bigsteve04tahoe Posted July 16, 2012 Report Posted July 16, 2012 Picked one up today for 100 bucks with a set of p3 12's. One was blown but i still think its a hell of a deal. No birth sheet though. Does anyone have a ballpark idea of what rms they put out? Pioneer AVH-P9400BH head unit Galaxy Tab as library for Bumps 1Tb hard drive for more music (only about 200Gb) Rockford T400.4 for mids and highs 2 Crossfire 1700d strapped for subs 2 Sundown Zv3 15 inch subs Power T1652s components in front and rear doors. Punch tweets in the A pillars Big 3 upgrade in 1/0 Future Plans Kick pods for some more T1652S components Maybe some SA8v2's in a custom console once i get around to building it.
bass_stalker Posted July 16, 2012 Report Posted July 16, 2012 simular to this i assume http://www.sonicelectronix.com/item_26140_Rockford-Fosgate-T500-1bdCP-2010-Model.html?SearchClickout[query_id]=11106274&SearchClickout[ignore]=1 JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Dan2427 Posted July 16, 2012 Report Posted July 16, 2012 My buddy had the old grey style the bigger amps and I had the T1000.1bd his T500 put out 1050 some watts at one ohm! My T1000 did 1624 at one ohm. I still think his was more impressive at double RMS power of what it's rated!! 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Sonic Posted July 16, 2012 Report Posted July 16, 2012 The T500-1bd puts out 250 watts of continuous power to your single 4-ohm subwoofer, or 400 watts to a pair of subs. Either way, you can depend on clean, powerful sound from your Power Series amp. Power Series amps use Rockford Fosgate's patented, award-winning "Dynamic Thermal Management," a 3-stage cooling system that uses forced air to dissipate heat evenly across the amp and out through the large heatsinks. This results in cooler internal components, higher efficiency, and lower distortion. Description : Rockford Fosgate T500-1bd Power Series 1-Channel Class BD Car Amplifier RMS Power Rating:4 ohms: 250 watts x 1 chan. 2 ohms: 400 watts x 1 chan. 1 ohm: 500 watts x 1 chan. [*]Max power output: 500 watts x 1 chan. [*]MOSFET Power Supply [*]This Class-BD amplifier has 75-80% efficiency ratings vs. 20-60% efficiency ratings of traditional class A/B amplifiers [*]Built-in differential inputs eliminates noise picked up the signal cable [*]Remote bass level input (remote level control sold separately) [*]LED power, thermal, and protection indicators [*]Tuned Bass EQ (0-12 dB bass boost at 45 Hz) [*]Audiophile grade speaker connections [*]Infrasonic filter [*]1 pair RCA Input [*]1 pair RCA Output [*]RCA pass-thru [*]Cast aluminum convection cooling evenly distributes excess heat across entire amplifier heatsink [*]Variable low-pass filter (35-250 Hz, 24 dB/octave) [*]CEA-2006 compliant amplifier [*]Frequency response: 20-25000 Hz [*]Dimensions: 11.41" L x 8.14" W x 2.14" H [*]4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
bigsteve04tahoe Posted July 17, 2012 Author Report Posted July 17, 2012 I appreciate the input from everybody and i know what its "rated" but i know every birth sheet shows gobs more power, i was just wondering what some people had seen or thought. Pioneer AVH-P9400BH head unit Galaxy Tab as library for Bumps 1Tb hard drive for more music (only about 200Gb) Rockford T400.4 for mids and highs 2 Crossfire 1700d strapped for subs 2 Sundown Zv3 15 inch subs Power T1652s components in front and rear doors. Punch tweets in the A pillars Big 3 upgrade in 1/0 Future Plans Kick pods for some more T1652S components Maybe some SA8v2's in a custom console once i get around to building it.
bigsteve04tahoe Posted July 17, 2012 Author Report Posted July 17, 2012 simular to this i assume http://www.sonicelec...?SearchClickout[query_id]=11106274&SearchClickout[ignore]=1 Thanks, i see where dynamic power is a conservative 690w. The other websites didnt show that info. Pioneer AVH-P9400BH head unit Galaxy Tab as library for Bumps 1Tb hard drive for more music (only about 200Gb) Rockford T400.4 for mids and highs 2 Crossfire 1700d strapped for subs 2 Sundown Zv3 15 inch subs Power T1652s components in front and rear doors. Punch tweets in the A pillars Big 3 upgrade in 1/0 Future Plans Kick pods for some more T1652S components Maybe some SA8v2's in a custom console once i get around to building it.
