going to be for a single 15" XL M2
currently getting about 1600rms (after i purchase h/o alternator will bump it up to 3k)
but, i want to build a box for myself and go kind of all out with it (glassed inside, 45's/possibly kurfs, etc.)
but i know i dont want aero ports (just due to me not liking how the look)
so, i need some recommendations for square port area.
other than that, its going to be 3.2 cubes (hopefully tuned to ~40hz) going into a 97 buick riviera
input welcomed and appreciated!
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Here is a suggestion, dims taken from your older thread:
Enclosure Specifications:
Fb = 38.3 Hz
Vb = 3.35 ft^3
External Height = 16 in
External Width = 37.5 in
External Depth = 17 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 37 1/2 x 16
Left & Right Sides = 14 3/4 x 14 1/2
Top & Bottom = 37 1/2 x 14 3/4
L Port Internal Assembly Parts:
Front to Back = 10 3/4 x 14 1/2
Extension = 6 x 14 1/2
Assembly guide (generic dimensions):
Edited by Joe X
Fb = 34 Hz
Vb = 3.7 ft^3
External Width = 38 in
External Depth = 18 in
Port Width = 3 3/4 in
Cut Sheet List:
2 x Front & Back (3 parts) = 38 x 16
Left & Right Sides = 15 3/4 x 14 1/2
Top & Bottom = 38 x 15 3/4
Front to Back = 12 x 14 1/2
Extension = 8 1/4 x 14 1/2
uh oh... haha i should have probably been clearer xP
i just need a suggestion for port area for an overpowered XLM2
then i was going to play with some designs on sketchup
i took the outer dimensions you gave me in the last thread, and tweaked it a little bit to be tuned higher for a little more spl
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Ok so I changed it to something more like you are looking for but I wouldn't like very much the results! :)
how come?
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
this is what im confused about
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
It's taste unhappily.. maybe hear some other systems to make your mind.
oh this wouldnt be a daily driver box
this would be a burp box for some local db drag
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
You have to know your vehicle's resonant frequency and tune in a way that the box peaks at that frequency, it's done with flared aeros since those let you fine tune easily and have low surface resistance/turbulence.
  • Who's Online   0 Members, 0 Anonymous, 2101 Guests (See full list)
