everything flat. That measns bass and treble at '0', not -8 and -4. Leave your gain all the way down. Play the tone you want, and slowly increase the gain until the clip light comes on. Then back it down a notch.
Are you using a remote bass knob?
Are your speakers hooked up when you are setting the amp? Should not have subs hooked up.
Is your car off? Should be off.
car is usually on, why would i want it off? and sub isnt hookhed up. and no bass knob, only gain. which i put in the middle, but never go above that either. . . as far as the EQ. i turned them down when i did the amp, didnt see the matter but ok ill leave it flat until after amp is set
turn the car off because the guy who designed the DD-1 said to do it that way. Also ignore the guy telling you to not run full tilt before breaking them in.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
So i redid with the car off, (i think that was it) and things seem to be better. sub gets warm after some serious bumpin and time and little smell but i believe that cuz of a dirty song so. thank guys!!
