SMZ2's Xterror. 1st Hairtrick!
I get my license back in exactly one month, and one of the first things I plan on doing is hearing this beast! :D
It should be completely done by then well the box atleast haha. Then after I save up some monies it will be time for some deadner, a new alt, and lots of batteries. The electrical is going to cost me a fortune I want to get a 270 amp mechman with adjustable voltage and I want to charge at 18v so I have a lot of research to start doing and monies to be saved well what I can save as mentioned earlier part time sucks and I need work on the weekends for some spare change.
This is the front view
a little closeup of what the block would look like. basically it's just a 4x4 piece of 3/4" MDF.
here's where it gets interesting, you're going to want to bore out a hole that's 3/4" deep and the diameter of the washer that's going in it. from there you drill a smaller hole in the center where your allthread is going to come through, and make sure it only sticks out 3/4" so you don't have anything sticking out of the bottom.
precise measurements are key. everything is centered 14" from the back of the box, and 8" from each of the inside walls, which would mean 9.5" from the edge of the box on the top and bottom.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
youre gonna want to double the whole front of that box though man.....lots of pressure from the wave collecting there
I totally understand where you're comin from. I just bought all new wires and a 4 channel. Next to come is a new alt, then batts, then a new amp, then new subs! All after finding a job >_> or if i can get the stuff sold that I'm selling, there's the alt and batts, then its just on to the amp and subs (:
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
What did it meter at with the ported box and then the 1st 6th order design?
BTW I love your 6th order and i really want to experiment with them eventually
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
yeah its me, brandon lol we will be looking some help towards christmas haha
Dang so you finally joined haha. Hey if y'all ever need some help at the shop just let me know I never have anything to do on weekends... thanks man and yes I doubled up the front
Wow that looks amazing man will this work with me only having one layer on the bottom? Also will this work better than the four angles I made?
That's the whole purpose of the 4x4 blocks, it makes the surface you're drilling into 1.5" thick, so you can recess all the hardware (nut, washer, allthread) into the first layer, and then you have the second layer which is the little block.
I think, if you can, you should use it in conjunction with the angle iron. little extra bracing never hurt :)
I'll try to do a cutaway view in MS paint.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 2192 Guests (See full list)
