quick Q about multiple runs
for doing my second run of 1/0,
it goes from batter positive to amp positive
then amp ground to frame
correct?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
yeah or you could do the ground directly to the battery. Is this run going from the battery to second battery or to the amp
2nd run to the amp
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
yeah run it straight to the amp, and I'd run one straight to the battery negative to amp negative as well.
alrighty cool
Is this run coming from a second battery?
no it is not
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Do you have a second battery?
nope not yet
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
im assuming no lol. why wud he run it from the front instead of rear if he had a second one
edit: jeeez ninja'd like 3 damn times today wtf is up with these asians
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
  • Who's Online   0 Members, 0 Anonymous, 1267 Guests (See full list)
