Max Dims in 98 Dodge ram 1500 5.2 ext cab seats removed.
50 wide
21 deep
30 tall. could go taller but want to see out back lol.
Port Sub facing Im not sure??? i had sub forward port passenger side but at these dims, up is the only option, maybe forward?
Big three in 4 Gauge
New OEM 145A alt
Soon to upgrade Batt. Maybe largest kinetik/ XS ? Add another matching batt. to stabilize voltage.
AMP T500 bdcp 800w @ 1ohm
Subwoofers
Sundown Audio E12D4 Two of these
Specs on sub
Fs35.8hz
Qes0.56
Qms6.79
Qts0.52
LE1.85mH
VAS47.6L
BL15.4NA
Cms0.13MM/N
Mms156.6Grams
Sens. n/a 1w/1m
Xmax 12mm one way linear
RMS400w
Displacement 0.12ft cubed
would like input on tuning frequency please? 28, 32, 35??? i listen to decaf, bass mekanic, lil wyte, jeezy, classic rock too but i usually turn amp wayy down lol.
Thanks All
Edited by severancej
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Only go bigger if you're gonna tune lower. I have an 8" RE that's in a box twice the size recommended tuned stupid low that plays the low notes in Put On, Rack City and Twista's Yellow LIght.
no back pressure ftw, i guess
I didn't say big box/low tuning was for everyone... but the general rule is a bigger box lends itself to lower tuning.
OP, you might need experiment a little to see what you like.
2007 Pacifica
I bet i will like a nice 32 hz tune for sure. the sundowns supposedly like smaller enclosures?
Can someone sketch me a nice box design subs up port up
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
Well they are here and are massive for 110$ each!
They play with a deeper tone for sure.
My box blows for these woofers I know its wayy offf
its not loud enough but it does sounds good.
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
Im going to take it easy on them hopefully two weeks I can build that side firing ported box that joex suggested 4 me!!! I was thinking crazy T lines....6th order. Probably way out of my skills lol.
Want to upload pics..embarrassed of that crappy carpeted box tho :/
Couldn't get help at the local shop setting gain so i found a 40hz -6db track and set voltage to about 28vac flat eq no peq my voltage dropped to 12.8 :/ don't think I'm getting 800 "birthed" watts but thats ok the new box will probably make a difference.
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
I tried to invert them but it was a failed attempt because without some kind of adapter ring I was worried about the surround brushing the edge of the cut out. Another thing is the mounting flange on the woofer isn't symmetrical so it favors being mounted traditionally unless I make that adapter price I thought up...regardless this box has gtg anyway so idgaf lol
Thanks all!
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
  • Who's Online   0 Members, 0 Anonymous, 955 Guests (See full list)
