Hair Trick ? please dont flame
And just in case let me put my Nomex suit on.
Do you think 4 15" subs with 10mm of xmax in a sealed box can pull off any type of hair trick?
If it matters each is getting 800 watts and teh subs would be in 1.5 cubic foot boxes each.
TIA
Rolex you sicken me.
Just let me finish my pie
~ Juice
need alot more info than that
edit: ohh sealed box? not a chance
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
Depends on cabin area.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
I have all the T/S specs if needed but as you said, if the fact that it's a sealed set up puts the nail in the coffin then there I have it.
So without ports there's no way to move enough air without having 10+ subs huh.
~ Juice
Cabin volume is 90 cubic feet / 2548 Liters
you will see better results with a ported box
I have 4 15" Kicker solo's S15d's. I dont think there is anything I can do for porting.
~ Juice
why not?
2005 Subaru Impreza
My build log.
Specs for the Kickers:
Fs = 18.84 Hz
Qms = 8.587
Vas = 10.32 cu.ft
Mms = 8.732 oz
Xmax = 0.375 in
Sd = 131 sq.in
Qes = 0.396
Re = 3.61 ohms
Le = 0.832 mH
Z = 4 ohms
BL = 3.674 lb/A
Pe = 750 watts
Qts = 0.379
1-W SPL = 88.8 dB
Otherwise I have 1 JL 12W7, I'm trying to avoid getting another.
I know the 4 15's will give me good clean hard bass, but something inside me still wants to pull off the hair trick.
~ Juice
why not?
I havent run any calculatots on the 15's but all the other searching I did on them got me NO good set ups with ported boxes.
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
