DC Sound Lab
Ok so Im still waiting for my car to get back from the dealership (having some warranty work done) But in the mean while Im getting my build kicked up again. The set-up will be 1 DC XL m2 10" on a DC 2.0k (1 ohm final load)
This is what I've come up with, let me know your thoughts on it.
The reason for the baffle being that way is so that it can be flush mounted to the mini-wall. Which will seal it all off from the trunk area. Here are the specs: (inches)
Volume
12" H * 10" W * 29.5" D = 1.44618³ ft
Port
10.5" H * 2" W = 21in² with a port length of 33.625" (which is about 33hz)
Sub will only get rated power @ 1 ohm off the DC 2.0k so with the Volume of 1.44618³ ft - .13402³ ft of 45s and port displacement - .18³ ft of sub displacement. The sub should be seeing 1.13216³ ft after displacement.
Hows my math, any suggestions?
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
  • Who's Online   0 Members, 0 Anonymous, 7441 Guests (See full list)
