gt58 Posted August 22, 2012 Author Report Posted August 22, 2012 I'm not sure how the CEA ratings work, but i'm gonna go out on a limb and say that that rating was done in 06. But i'm not gonna be captain hindsight here. "this amplifier is CEA-2006 compliant so all wattage specifications are true to industry standard. The Kenwood KAC-9105D also has the Capability for a 1-Ohm load to achieve over 900 watts RMS!"
gt58 Posted August 22, 2012 Author Report Posted August 22, 2012 like my rockford fosgate is rated at 1000 rms @ 1 but it actually pulls 1350 @ 1 @ 14.4. who knows until you clamp it lol
412 CVX Posted August 22, 2012 Report Posted August 22, 2012 I'm not sure how the CEA ratings work, but i'm gonna go out on a limb and say that that rating was done in 06. But i'm not gonna be captain hindsight here. "this amplifier is CEA-2006 compliant so all wattage specifications are true to industry standard. The Kenwood KAC-9105D also has the Capability for a 1-Ohm load to achieve over 900 watts RMS!" I still don't believe it lol. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
CleanSierra Posted August 22, 2012 Report Posted August 22, 2012 You should have screwed the port into the baffle. I see no screws attaching that port. I know you applied resin, but I'm not sure how much. Simply placing a few screws on the bottom of the box going into the port piece and the top for a total of maybe 12-14 screws total would have been a good way to assure the port doesn't wiggle loose. I've seen them do it before. Maybe not on a 300 watt sub, but it makes good habit to get into for higher power applications. Also, that amp will NOT do 900 watts clean and clip free. It will also go into protect like a motherfucker if you wore it at 1 ohm. Im not the one you want to try to troll. Just a fyi for you.
gt58 Posted August 23, 2012 Author Report Posted August 23, 2012 You should have screwed the port into the baffle. I see no screws attaching that port. I know you applied resin, but I'm not sure how much. Simply placing a few screws on the bottom of the box going into the port piece and the top for a total of maybe 12-14 screws total would have been a good way to assure the port doesn't wiggle loose. I've seen them do it before. Maybe not on a 300 watt sub, but it makes good habit to get into for higher power applications. Also, that amp will NOT do 900 watts clean and clip free. It will also go into protect like a motherfucker if you wore it at 1 ohm. we used the nail gun and used a good amount of resin. the amp claims 900@2 2 ohm load, hes got the dual 4. its a "300" rms sub, with his current electrical he could expect a clean 700 on it? on stock batt/alt + big 3 + dd1 tune for the clean signal.
412 CVX Posted August 23, 2012 Report Posted August 23, 2012 Probably not. stock alt charges at 13.5 normally. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
gt58 Posted August 23, 2012 Author Report Posted August 23, 2012 i'll try to clamp the amp after the dd1 tune and see whatsup
gt58 Posted August 24, 2012 Author Report Posted August 24, 2012 did one more coat of flat black, decided on skipping the clear coats we will be touching up around the woofer where the tape covered a little bit of the wood.
UhOh Spaghetioz Posted September 6, 2012 Report Posted September 6, 2012 did one more coat of flat black, decided on skipping the clear coats we will be touching up around the woofer where the tape covered a little bit of the wood. Looks great. How she sound?
USAFBordeaux Posted September 6, 2012 Report Posted September 6, 2012 should of at least gone with an audiopipe amp lol. no matter where I go, no matter what I do, no matter the choices I make... I will always have bass. Ba$$H34Ds unite. Audio Modifications Big 3 Upgrade
