81000D Posted July 25, 2012 Report Posted July 25, 2012 If I have sub up port side should my phase switch be normal or reverse?
andrew018018 Posted July 25, 2012 Report Posted July 25, 2012 You would normally shift the phase 180 degrees if you would reverse mount a subwoofer, there are other uses for the phase nob but you shouldn't need them. My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
wmrcs Posted July 27, 2012 Report Posted July 27, 2012 I've been curious about this also. What exactly does the phase DO? E34 540iT/6
Guest Posted July 28, 2012 Report Posted July 28, 2012 changing the phase makes it on time with the music, your subs when they hit, hit outwards, inverting them will make them hit in the same direction (which would be into your box) so you flip the polarity so its on phase (timing). so it will hit outwards again. you switch the phase when you invert a sub. (mount it backwords with the motor out).
wmrcs Posted July 30, 2012 Report Posted July 30, 2012 changing the phase makes it on time with the music, your subs when they hit, hit outwards, inverting them will make them hit in the same direction (which would be into your box) so you flip the polarity so its on phase (timing). so it will hit outwards again. you switch the phase when you invert a sub. (mount it backwords with the motor out). I always just leave the phase alone and reverse the polarity? E34 540iT/6
Tebo Posted July 30, 2012 Report Posted July 30, 2012 Thats another way to do it if your amp or head unit doesnt have the phase selector option 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
wmrcs Posted August 3, 2012 Report Posted August 3, 2012 Hmmm. Soo what happens if the phase is at 90 degrees E34 540iT/6
