Hey guys, need a straight forward box design for (2) Sundown SA-15 dual 4 subs. Will be powered hopefully by a Skar or Sundown 1500 Watter. Max dimensions are 37wX34dX25h. Goin in a 2001 Olds Bravada. I built a box before so I learned a little. So not looking for an outrageous box, just something basic. Subs up port back? Subs up port up? Also will be putting in a false floor.
How about....subs up/port back............18"h x 37"w x 30"d.....port 15.75"h x 6.25"w x 20"d.......double baffled.........that's about 7.5 cubes net.....33hz
That sounds about exactly what I need. So is that port a center port or port at the bottom? I dont have sketchup so if someone can chime in and do me a rough draft and a cut sheet ill greatly appreciate it!
Dont mean to bump but was also wondering if aeroports would work in my situation?? Thanks guys for any help!
Cool looking boxes but not feeling the side port look. Want something more towards the middle or bottom like this on my old box I built. Definately need a cut sheet.
Posted (edited)
18"h x 37"w x 34"d..........Port on bottom.....3.75"h x 35.5"w x 30"d........34 hz..........7.2 cubes........
Try the above measurements...........below is an enclosure with that type of port I done a while back...
Edited by pwdrblucivic
