David Posted November 7, 2006 Report Posted November 7, 2006 i made a mistake look here your port length should be 5.714 for 35hz QL = air los from leaks, how your suppose to know this I have no Idea, I'm no Expert with this proggie, I make it work for me thou, its trail and error, also the help guide is AWESOME
Ernesto Posted November 7, 2006 Author Report Posted November 7, 2006 i made a mistake look here your port length should be 5.714 for 35hz QL = air los from leaks, how your suppose to know this I have no Idea, I'm no Expert with this proggie, I make it work for me thou, its trail and error, also the help guide is AWESOME What do you put for QL? 0 ?
David Posted November 7, 2006 Report Posted November 7, 2006 where can i get bass box pro from? you gotta buy it. http://www.ht-audio.com/
Ernesto Posted November 7, 2006 Author Report Posted November 7, 2006 yupLet me see what I can come up with :-[
Ernesto Posted November 7, 2006 Author Report Posted November 7, 2006 Well I'm able to enter my tunning this time but now my box dimensions automatically adjust due to the "VB"...I don't know what the hell it is or what to put :-[
David Posted November 7, 2006 Report Posted November 7, 2006 um tommorrow I out put the box for you, :-[
Brian Mizell Posted March 23, 2012 Report Posted March 23, 2012 where can i get bass box pro from? Give me an email address and I'll hook you up..... Edit: I just realized this thread is OLLLLLD!
Droppin Low Posted September 23, 2018 Report Posted September 23, 2018 click on bass box pro icon then click on design wizard click on start with diver then click next then click search driver database then click next under company search for the name of your drive Rockford Skar ext then click on drivers found tab click your diver model than from there click on the blue load button on the bottom right corner from there another box comes up there you will choose how many subs you are working with if it will be isobaric push-pull and wired in series or parallel from there then click the green accept button another box will come up asking you to click next do so next it will ask you what type of box you want to build read what it says before click next because its important to the type of box you'll be building after reading click next next will be another box where it gives you the option of choosing the type of box you want to choose what you want to work with than click next yet another box will pop up in this box is where you ad your dimension the tabs at top also give you options as well if you want to add polyfill under damping or not vent is where you figure your port out the interior tap is where you decide whether you want front mount rear mount or flush your sub after your done with all that click the green button accept another box pops up click next now another box pops up this is to analyze your box design once you have click the blue button finish now you should be at the window where you have a bar graph of your band with click the box tab that will take you back to the box design click on parts list that will give you your cut sheet modify as needed
