Been working on this for a while but finally getting some build pictures up. Doing full rebuild on the Civic.
Equipment
OLD
4- DD 2512 Dual 4
1- DD M2a
1- DD C2b
1- DD C3b
2- DD 6.5 Component Sets
1- DD 5.25 Component Set
3- Kinetik HC-2400
NEW
4- DD 2512 Dual 4
1- DD M2a
1- DD C2b
1- DD C3b
10- Selenium 8w4p
6- Power Acoustik NX-5
5- Shuriken BT-60
Old Setup (153 at 54hz, 149 at 29hz)
Finally have some updates been a while but had a lot problems with the roof from the years of abuse. Also decided to wall it off again.
Built a top piece to make the wall which holds. 8 Selenium 8w4p and 4 Power acoustic NX-5s.
Then it went into the body shop for about 2 weeks. Window was leaking and all the spot welds on the front of the car were broken. So I had it braced and fixed. It has a piece of 1"x1"x1/8" angle iron running the length of the roof and then that was boxed in with 3 layers of 1/8" Plate steel. The window lip is about a 1/4" thick and all welds are solid or plug welded. They also rewelded the second brace back on.
