I just bought a kicker cvr 12", and I am very confused on how to make the box. Ive looked at the box calculator on re audio, but it is supposedly inaccurate. I dont really know where to start. Any help would be greatly appreciated.
in the enclosures section, there is a thread stickied called Torres. download it and READ THE INSTRUCTIONS. the program itself has a built in help file which is really helpful.
look around on the forum for other people that are using cvr's. i know kicker subs like bigger boxes.
Have you downloaded any type of sub calculator? Many times if you go their website they give you useful info for your sub.
Post vehicle, amp models, max dims amd music type you listen to. I can provide you as suggestion or help to create your own.
I have a honda accord coupe, its a pretty small car. I listen to mostly rap and my goal is to get as much bass as possible out of the single cvr. I think im supposed to make a ported box but i'm not sure.
Ok you have an Accord, what are the max dims for the box and what's the model of the amp.
im not sure what you mean by max dims (this will be my first system) , and im getting the Kenwood KAC-8105D
Yes the size of the box biggest you can fit for a sub inside your trunk: height,width, depth so that I can post some plans for you.
Ok here is a suggestion:
Enclosure Specifications:
Fb = 35 Hz
Vb = 2.25 ft^3
External Height = 15 in
External Width = 25.75 in
External Depth = 17 in
Port Width = 2 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 22 3/4 x 13 1/2
Back = 25 3/4 x 13 1/2
Left & Right Sides:
Side 1 = 15 1/2 x 13 1/2
Side 2 = 16 1/4 x 13 1/2
Top & Bottom = 25 3/4 x 17
L Port Internal Assembly Parts:
Front to Back = 13 1/4 x 13 1/2
Extension = 6 1/2 x 13 1/2
Any changes, comments or questions let me know.
