Anyone have some experience or some help they could give me for building a box. It's going into a 2000 jeep grand cherokee and it's a single kicker L7 15"
Thanks.
Post your max dims for the box. and amp model.
38" Long
18" High
20" Width
DX 1000.1 Mono D block amp - 1036 RMS
Those are what i'm working with. As for the measurments they can rise a little if needed.
So here is a suggestion Subs up/port back:
Enclosure Specifications:
Fb = 34 Hz
Vb = 5 ft^3
External Height = 18 in
External Width = 38 in
External Depth = 20 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 38 x 20
Left & Right Sides =
Side 1 = 18 1/2 x 15 3/4
Side 2 = 19 1/4 x 15 3/4
Front = 33 x 15 3/4
Back = 38 x 15 3/4
L Port Internal Assembly Parts:
Front to Back = 14 1/4 x 15 3/4
Extension = 2 x 15 3/4
Assembly guide (generic dimensions):
Double baffle is recommended but not strictly necessary.
Let me know any changes, comments or questions.
Fb = 34 Hz
Vb = 5 ft^3
Cut Sheet List:
Front = 33 x 15 3/4
Back = 38 x 15 3/4
Thank you very much! This is very helpful.
I have kind of the same question, But I'm trying to squeeze my 15 inch L7 in the back of my volvo S70. I'm been messing with Torres and Google sketch and have came up with several boxes. but I want the best bang for the space. I have limits on it due to the trunk but maybe you guys can help me out and take advantage of the center arm rest that folds down in the middle of the back seat for where the port should be. (probably a bad idea but I'm looking for something to really pound) 17H x 44W x 17D
http://s2.photobucket.com/albums/y39/beyondboost/633K/?action=view&current=15L7final1.jpg
this is the 17 inch tall box I made up using Torres
http://s2.photobucket.com/albums/y39/beyondboost/633K/?action=view&current=FinalBoxSpecs.jpg
thanks in advance
Boost
Fb = 34 Hz
Vb = 5 ft^3
Cut Sheet List:
Front = 33 x 15 3/4
Back = 38 x 15 3/4
you're always so helpful with this kind of threads...
audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
Fb = 34 Hz
Vb = 5 ft^3
Cut Sheet List:
Front = 33 x 15 3/4
Back = 38 x 15 3/4
Unless aero ports are needed....
I've done a lot of research, don't buy the L7. You can get something a lot louder for a lot cheaper.
:WTFBubble:
  • Who's Online   0 Members, 0 Anonymous, 6441 Guests (See full list)
