How much rms do you lose when voltage drops?
If your electrical is grade A, then why are you dropping 2V?
To fully answer your first question, is your amp's power supply regulated or unregulated?
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
ment not grade A, fixed. . . and how do i find out if it is or isnt. its an American Bass HD 3500 to my knowledge, its non regulated, again just some quick googling and nothing for sure but i think that was it is Edited by Mikey Bates
The AB website doesn't get into that much detail but it doesn't state that the amp outputs more with increased voltage so I'll assume that its regulated.
Theoretically a regulated supply will try and maintain the output with a varying input.
Therefore if your input voltage fluctuates, the amp will pull more current to compensate and output the same power.
As long as you're inside the amp's specifications, it "should" output the same power with a dipping input voltage.
Anybody that is more familiar with AB amps, feel free to chime in.
If you're that curious about it, then you may have to buy the clamp and measure it...or contact American Bass Technical Support if there is such a thing and ask them?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
What notorious was trying to say, which is a good point I add, is that unless you are actually competing and trying to squeeze out as much juice as possible, it shouldn't matter. No setup sees full power all day every day, especially on music. Even if you kept voltage at 14.4 volts you are still forgetting about impedance. Buying the tools suggested would help you clamp and see what power you are getting, but you are still not seeing full power as nominal impedance is different than reactive. And its ok. Rise helps setups by the thousands. Just letting you know voltage is only a single part in the big picture.
  • Who's Online   1 Member, 0 Anonymous, 1364 Guests (See full list)
