bassface Posted August 2, 2012 Report Posted August 2, 2012 Its still going to get hot no matter what because its bolted to an engine block that is designed to run at 180 degrees or even more. Quote
Kyblack76 Posted August 2, 2012 Author Report Posted August 2, 2012 (edited) Yeah ...i understand that...... This reading was after a 5 minute ride.......... That is my concern....... again,... i will take another reading, after a trip from work, afternoon when the ambient is up and the AC is going nuts,,... all that good stuff... What will happen if i just sit there,.. demo'in for 4 hours, in 99 degrees..... YADDA YADDA... Edited August 2, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted August 2, 2012 Author Report Posted August 2, 2012 (edited) Also, am i taking life away from the unit?????.... is there anything i can do the help?.... I don't think it's hurting it. They are designed to run at that temperature If you really want to help cool it, go to home depot and get some dryer hose. Remove a fog light and pipe the hose up and make it blow on the side/back of the alternator. Add a fan if you want cooling at a stop too since this method only works when driving Good and bad,.. right in front of the elec fan, But,righ next to the exhaust.... Edited August 2, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
aerickson Posted August 2, 2012 Report Posted August 2, 2012 Yea It might get toasty cuz its right buy the exhaust. Quote
Kyblack76 Posted August 2, 2012 Author Report Posted August 2, 2012 (edited) Yea It might get toasty cuz its right buy the exhaust. Yep, but, it is right by the fan that jumps on at hight temps, the aux fan that kicks on, and off... Edited August 2, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
aerickson Posted August 2, 2012 Report Posted August 2, 2012 I think so. Poor water on it, then it will be cool. Jk Quote
Kyblack76 Posted August 2, 2012 Author Report Posted August 2, 2012 (edited) I think so. Poor water on it, then it will be cool. Jk Ahhhhhhh...... ,... I just hate how hot it gets under there..... More tomorrow Again, thanks for any and all help all.. (even you aerickson) Edited August 2, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bassface Posted August 2, 2012 Report Posted August 2, 2012 Yea It might get toasty cuz its right buy the exhaust. Yep, but, it is right by the fan that jumps on when something says somthing..The AUX fan..... .... hmmmm.... a switch to keep said fan on when KYLE says so?????..... hmmmmm.. Tony, where are you?...... all you would have to do is remove the wires from the thermostat switch and hook them to a toggle switch if you wanted to run the fan manually. Quote
