Yeah ...i understand that......
This reading was after a 5 minute ride.......... That is my concern....... again,... i will take another reading, after a trip from work, afternoon when the ambient is up and the AC is going nuts,,... all that good stuff...
What will happen if i just sit there,.. demo'in for 4 hours, in 99 degrees..... YADDA YADDA...
Edited by KyLar96
Also, am i taking life away from the unit?????.... is there anything i can do the help?....
I don't think it's hurting it. They are designed to run at that temperature
If you really want to help cool it, go to home depot and get some dryer hose. Remove a fog light and pipe the hose up and make it blow on the side/back of the alternator.
Add a fan if you want cooling at a stop too since this method only works when driving
Good and bad,.. right in front of the elec fan,
But,righ next to the exhaust....
Edited by KyLar96
Yea It might get toasty cuz its right buy the exhaust.
Yep, but, it is right by the fan that jumps on when something says somthing..The AUX fan.....
.... hmmmm.... a switch to keep said fan on when KYLE says so?????..... hmmmmm.. Tony, where are you?......
all you would have to do is remove the wires from the thermostat switch and hook them to a toggle switch if you wanted to run the fan manually.
