aerickson Posted August 2, 2012 Report Share Posted August 2, 2012 Cuz 0g won't fit his amp probably. Quote Link to comment Share on other sites More sharing options...
imnew59585 Posted August 2, 2012 Report Share Posted August 2, 2012 i know but thought i would state it. but yeah look into them converters Quote Link to comment Share on other sites More sharing options...
ewilliams5430 Posted August 2, 2012 Author Report Share Posted August 2, 2012 There are adapters,.. nice adapters made to get your 1/0 to get into a 4g Dude,... I have to know what amp you have?... 2k with a 4g input.... what amp you running my friend? My 1000.4ad that BS at close to 300 per channel has 4g toss ins as well...... just asking is all bud.. I am running an hfi2000d that I got for a steal brand new Quote Link to comment Share on other sites More sharing options...
ewilliams5430 Posted August 2, 2012 Author Report Share Posted August 2, 2012 I never thought of size adapters though thanks guys. But the only reason I suggested the distribution block is because I will be adding another amp soon and getting some mids and highs to replace the doors. Just slowly piecing my system together as I get the money. I'm ordering a h/o alt soon Quote Link to comment Share on other sites More sharing options...
HunterJohnson Posted August 2, 2012 Report Share Posted August 2, 2012 you can also solder the shit out of the wire then grind it down so it fits perfectly, or just chop some off whatever floats ur boat. just options using stuff you alrdy have instead of gauge reducers and distro blocks Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
ewilliams5430 Posted August 2, 2012 Author Report Share Posted August 2, 2012 One more question, would a 230a alt be okay for my amp with stock battery or would I need a better one? Such as xs? Quote Link to comment Share on other sites More sharing options...
HunterJohnson Posted August 2, 2012 Report Share Posted August 2, 2012 that'd be plenty for sure. dont need another battery but a nice agm battery wouldnt hurt Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
flashlight_65 Posted August 2, 2012 Report Share Posted August 2, 2012 You can also use one of these http://www.sonicelectronix.com/item_17815_Kicker-09DB1448-DB1448.html And it gives you the flexibility to use straight 4 gauge to your sub amp or 1/0 with 1/0 to 4 gauge reducers. I'll draw you up a diagram in a bit Quote My builds: my caddy my 'hoe friends impala Link to comment Share on other sites More sharing options...
flashlight_65 Posted August 2, 2012 Report Share Posted August 2, 2012 (edited) Hopefully this makes sense Make sure you use the same size wire for the ground that you do use for the power wire on the amps Edited August 2, 2012 by flashlight_65 Quote My builds: my caddy my 'hoe friends impala Link to comment Share on other sites More sharing options...
imnew59585 Posted August 2, 2012 Report Share Posted August 2, 2012 option 1 seems to be the best, but if im correct you mite wanna have two batts if your running two amps, depends on your amp and sub set up but it will be something to look forward for in the future Quote Link to comment Share on other sites More sharing options...
