the peak of the amp does not exced subs peak.
I have two subs and the amp, but I don't have to use both
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
gain will be set correctly, not used as a volume control
Do one for now. Push it good and if it blows use the other one.
thats a good answer. its a glass enclosure, so i just want more info before i get to far on it, if i change my mind
I am going to run a three inch port out the passenger side. plus, i'm not sure i like the way i laid it out..
Edited by jhmeg2
Come is king on low power,
2 for sure, you can alway upgrade amp latter, but building a box in glass for another because your not happy with 1 is a pain in the ass
2 and good clean power
this doesn't seem like a good idea.
OP if you want to use one sub on that amp the I suggest selling both and upgrading. if you don't then I suggest using ones right now underpowered and if you want more then you can upgrade
your saying run two, and upgrade amp latter... ok that makes sence.
If your under rms iv heard you can make up for out but making the box bigger than to spec.
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
