Power or Cone Area
I've always been confused as to what contributes more toward overall loudness. I do know that increasing power makes a system louder and increasing cone area to push air makes a system louder also. But what contributes more to loudness? For example, to add on to a system of two 12s on 2k watts: Would two 12" subs on 4k watts be louder than four 12" subs on 2k watts?
there is no cut and dry answer to this.. more cone area makes it easier to get louder..and so does power..but what they will do can be very application dependent
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
cone area is KING!!! ahah
youll never know till you try. it would be a tough call. would you be underpowering the 4 subs versus powering the 2 subs right? if the sub doesnt reach high efficiency and displace a lot of air then youd most likely be louder with 2 on proper power opposed to underpowering 4 while you watch them bump there without any excursion
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
This is all hypothetical because I've always wondered. And the subs would be matched to the amp so they would be getting rated rms
id take the 4 subs on rated if you can fit. versus 2 subs rated on 2k
BMW M340 xDrive
  • Who's Online   1 Member, 0 Anonymous, 834 Guests (See full list)
