imnew59585 Posted August 8, 2012 Report Posted August 8, 2012 I've heard AB TNT 10's there like 80-100 some where in that range but i dont remember the rms tho
Guest Posted August 8, 2012 Report Posted August 8, 2012 sandpaper or a grinder (if you have one) tape to cover the gap. not that clear shit you use to wrap christmas presents cyanoacrylate glue enough (lots of) clamps to go around the outside of the sub something to center the coil in the gap
Guest Posted August 8, 2012 Report Posted August 8, 2012 I've heard AB TNT 10's there like 80-100 some where in that range but i dont remember the rms tho they're 600w http://www.ebay.com/...=item3f1a4d295b no warranty from american bass themselves though. just through the reseller. just stating
ALPINE408 Posted August 8, 2012 Report Posted August 8, 2012 Let not forget the fun task of cleaning alll the old glue off Things you need to recone I use A utlity knife and hammer to get most of the foam and spiders off An Angle grinder and flap disc to clean it the rest of the way I found with these tools its the fastest simplest way to get the baskets in recone condition The CA glue shims for the coil and pole piece gap some 5 pound weights and a shit load of pessure clamps The you will need wire cutters and a soldering gun with solder Have you ever had your woofers blown?
imnew59585 Posted August 8, 2012 Report Posted August 8, 2012 it says 30 days, but yeah so you got 1100 watts, together they would be 1200 rms so yeah its only 100watts off
Guest Posted August 8, 2012 Report Posted August 8, 2012 Let not forget the fun task of cleaning alll the old glue off Things you need to recone I use A utlity knife and hammer to get most of the foam and spiders off An Angle grinder and flap disc to clean it the rest of the way I found with these tools its the fastest simplest way to get the baskets in recone condition The CA glue shims for the coil and pole piece gap some 5 pound weights and a shit load of pessure clamps The you will need wire cutters and a soldering gun with solder i think the chances of OP fucking this up are huge. my honest opinion.
imnew59585 Posted August 8, 2012 Report Posted August 8, 2012 Let not forget the fun task of cleaning alll the old glue off Things you need to recone I use A utlity knife and hammer to get most of the foam and spiders off An Angle grinder and flap disc to clean it the rest of the way I found with these tools its the fastest simplest way to get the baskets in recone condition The CA glue shims for the coil and pole piece gap some 5 pound weights and a shit load of pessure clamps The you will need wire cutters and a soldering gun with solder i think the chances of OP fucking this up are huge. my honest opinion. to get better is to learn from your mistakes
