fx4trucker Posted August 6, 2012 Report Posted August 6, 2012 i just got doing some routine maintenance on my system. when i check the main power wire (4ga efx) in the rear where i have it split i notice something odd.. the wire sleeve was split down about 3" so i went to fix it and notice the top of my RF distribution block it wasnt coming off .. with some force i got and thats when i notice it was all melted and twisted .. the fuse did not blow (100 amp glass) this line goes to my sub amp . where nun of the fuse on it were blown .. its an interfire 03 model .. just wondering what could cause this ? i have never had this b4 alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers. 1. set is in the a-pilors 1. memphis mojo 2500 watt amp 1. rockford fosgate t2 15" dual 2 ohm wired to 4 ohm . seeing 600 watts 1. realm audio 600 watt 4ch
Skullz Posted August 6, 2012 Report Posted August 6, 2012 Loose connection that caused resistance to heat it up to the melting point. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
fx4trucker Posted August 6, 2012 Author Report Posted August 6, 2012 Loose connection that caused resistance to heat it up to the melting point. that makes sense. i made sure that is was tight this time .. i have to hand it RF for making a grate product lol it still all works .. thanks for the help ... alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers. 1. set is in the a-pilors 1. memphis mojo 2500 watt amp 1. rockford fosgate t2 15" dual 2 ohm wired to 4 ohm . seeing 600 watts 1. realm audio 600 watt 4ch
