need a box design for a blaupunkt 18inch
NZBasshead
the details of the woofer are
Subwoofer with a diameter of 460 mm and 5400 watts of max power.
Specifications
System Subwoofer
Diameter (mm) 460
Peak power handling capacity 5400 watts
Nominal power handling capacity 1800 watts
Sensitivity 94 dB (2.83V/1m)
Frequency response Hz 20 - 200 Hz
Impedance 2 x 2 Ohm
Cone material Carbon/fibreglass
Installation depth 245.0 mm
Installation Ø 420.0 mm
Hole circle 452.0 mm
Included Design cover
Thiele/Small parameters
Fres 37 Hz
Qts 0.6
Qes 0.71
Qms 3.8
Vas 36.7 l
Xmax + / - 15.0
Enclosure recommendation
Bass reflex 60 litres
Tunnel Ø 2x 10 cm
Tunnel length 2x 80 cm
the amplifier power i have is 2 3500 rms amps strapped @ 7000 rms
the woofer takes that power quiet well so far with the box ive got but i dont think it sounds that decent in the box i have
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
