Re audio 12 inch srx weird ohm reading
Got a new re audio srx 12 inch dual 2 ohm I wired it 4ohm but when I test my wires going to the amp it reads 6.8 ohms. I double checked the box and it states dual 2 ohm not the 4 ohm one. Anyone had this problem with the srx 12? Or any other sub? Did I just mess up the wiring or r they just high? Any thoughts?
i had 2 12'' srx subs on 1000 rms and loved them!! never had a problem intell i put 2 k rms on each then poped them. they take some power alot more then the RMS on them.... Edited by sbg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Sounds a little too high.....double check your wiring here
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?AspxAutoDetectCookieSupport=1
If everything checks out ......try using a different multi- meter
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
Only running ~300rms to them until I figure this out, I don't want to have the wiring messed up and blow it before I can give them any real power. What sized box were using? Just curious
i used a prefab BBox slot,, it worked good i think it was tuned to 38hz but not sure..
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Test the resistance of your prongs first, touch them together and see what the ohm reading comes out to. Then measure the subs normally and subtract that number from the ohm reading of the subs and you'll get the correct reading.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Test the resistance of your prongs first, touch them together and see what the ohm reading comes out to. Then measure the subs normally and subtract that number from the ohm reading of the subs and you'll get the correct reading. I just tried and it sits at .1 so the subs ohm is still reading high
Edited by Jeffl
Checked using that site and I have it wired "right" never had any issues with this ddm, check my other subs with it and it's spot on
do they play ok with power? what u runing for a amp? 6.8 ohm is way off
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1415 Guests (See full list)
