help with sub box
Can someone help me with a sub box design? I'm doing 2 15" kicker cvrs I want it to be around 7-8 cu ft. Port amd subs on top and also want a amp rack to be facing the hatch. It's for a 1999 dodge Durango 5.9 v8
1999 Durango
Current
2 15" DC level 3 15s
kenwood HU
Cresendo bc2000
Big 3 upgrade
Sky high car audio wire
Coming soon
Cresendo c1100.4
double din
New Build log
http://www.stevemeadedesigns.com/board/topic/168661-99-durango-dc-audio-package-in-and-box-almost-done/?p=2464991
Clean Build log
http://www.stevemeadedesigns.com/board/topic/171619-dc-audio-durango-clean-build/
30-35" seat to hatch 42" max .
45"wide
16-18" high
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
half inch mdf? are you mad?
edit: plus that port position you did in sketchup, is 3 common port walls. plus the height of the port in relation to the box height is wrong for the thickness of wood you're using.
Edited by Kranny
I am indeed mad, it's going to be braced to hell and back. I realize my port wall mistake, but height is wrong, wat? 1/2 " x 2 = 1 inch 17 - 1 = 16.. lol.
2012 TORed Challenger
4 Alpine Type-R 10
1 Brutus 2400.1
20' Knu 1/0 OFC
1 XS Power D1200
How in the HELL do you get a screw into 1/2" MDF?!?!?! I have an easy enough time, even pre-drilling splitting 3/4" MDF. 15" subs+ 1/2" MDF seem like a terrible combo in my opinion.
Can some one make a 3D sketch with demensions? And a port that faces the harch that I could also build a amp rack on it.
1999 Durango
Current
kenwood HU
Cresendo bc2000
Big 3 upgrade
Coming soon
Cresendo c1100.4
double din
New Build log
Clean Build log
Originally drawn for more powerful subs, have replaced 15" CVR displacement and the result is as follows:
Enclosure Specifications:
Fb = 35.8 Hz
Vb = 8.6 ft^3
External Height = 18 in
External Width = 44 in
External Depth = 30.75 in
Port Width = 8 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 44 x 30 3/4
Left & Right Sides = 29 1/4 x 15 3/4
2x Front = 17 5/8 x 15 3/4
Back = 44 x 15 3/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 18 3/4 x 15 3/4
45s are 3" wide, the box gives you an upgrade path if you decided to upgrade.
  • Who's Online   0 Members, 0 Anonymous, 557 Guests (See full list)
