ALT , BATTERIES AND WIRE RUNS
dang i thought Steve was running three alternators. what happened? anyways i priced a $240 amp alternaor from Irragi and he quoted me at $359. i drive a 04 ford expedition.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
WORD!  :-* Thats not bad. I can spring about $800 for 2- 275amps or 2- 300 amp Iraggi's. Which one does the best for street vehicles, cuz I heard someone say that the mid200amp ones do more at idle than the big 300amp ones? Which 2 do yall think I would need (just daily driven ground pounder with a/c + heat, hyper white lights, about 5 TV monitors and 6 deep cycles with 920amps-1800amps of fuses)?
00114-1.jpgTEAM MechMan Alternators
well irraggi also quoted me a 220 amp too and it ran $239 and he said that it would put out more amps at idle than the 240. i might just go with the 220 amp alternator, it's only $20 cheaper but i can use the idle power.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
that's what i'm planning on doing. my RPMs are only up when i'm on the highway and heck i don't play it that loud when i'm doing 70 mph. i need it to blast when i'm doing 35 and under.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
220 $339
240 $359
260 $379
280 $399
300 $419
Dual alt brackets. $219.00
Triple alt brackets. $678.00  (Much different bracket)
I think the way he said they work is those are the amperage but he has 2 in each amperage rating one just does more at idle but both do the same at higher RPMs. So Imma get 1 of each 300amp alts and the dual bracket=1057+shipping....dat aint bad cuz I know with 600amps of alts I have plenty of room for upgrades.
220 $339
240 $359
260 $379
280 $399
300 $419
Were did you get the pricing for the dual alts? You could probably DIY and it would be a hell of alot cheaper.
