I have a Mazda MPV(van). I plan on running 80 watt 6x9's in the doors, 100 watt tweeters in the dash, 2 sets of 60 watt tweeters between front and back. The back seat will be removed and there will be 4 12's pushing 3100 watts. I am debating on 2 different setups. 3 pairs of 100 watt 6x9's or 2 pair of 100 watt 6x9's and a pair of 125 watt 8's(freq. response is 90hz-5khz). I was going to angle 1 or 2 pair toward backset and the other(s) straight up. Any ideas on this or perhaps another setup?
Wow you got a lot goin on.. It sounds pretty bad, honestly. Its pretty apparent that you arent after sq, (which is fine!) Habe you considered pro audio stuff? Id never run em myself, but I bet they'll fit what you're after!
I dont have the time to get into this right now, but i would recommend you take some time to look around the site and look through some of the member build logs before you go down the road of what you are talking about.
I think you will reconsider what you are planning on doing and hopefully a much better system will come out of it.
I'm pumped you are on here and trying to put some good sound in your car so be patient and listen when people try to help you out!
Team NorthWestSPL
Dont run oblong speakers. Always run circle.speakers
They sound better or something? My doors hold 6x8 speakers but I seen brackets to fit smaller 5.25's. I have 6.5 comps that I am trying to use in another build later.
I didn't realy consider it a big build compared to some of the other things I have seen on the internet. It is only going to have 4 amps, 2 mono and 2 4 channal. I know having that many 6x9's is going to pull the imaging to the back, but didn't realy want to fiberglass pods or anything. Maype in the future. Actually, I am into sound quality but also like to be loud. That is what I use my settings for, crank the subs a 3rd of the way and get everything else to matchup. Dont have to have the 6x9's playing full tilt all the time.
Why do you cosider it such a bad idea? Can you please give me more info, please. Man, you make it sound horrific. LOL. Not being a d###, just curious.
