Wiring question
Ludachris5150
This is the diagram im questioning...
Ok so I have 2 sa-12s, D4 and a crescendo bc2k im trying to run at 1ohm. Im wondering what this picture is saying exactly? Is it saying run each - and + output wire on each sub to both sets of -'s and +'s on the amp, 1 sub per. Or is it saying take both - output wires and both + output wires and only run them off 1 - and 1 + on the amp? Sorry if the question is hard to understand. Basically is the 1st or 2nd picture the way to wire
Should I wire it like this
Or is this how its supposed to be done
Rebuild in progress...
As long as ALL positive terminals from the subs make it to one set of positive outputs on the amp and ALL negatives make it to a negative output on the amp, it doesn't really matter how you do if. All + to + all - to -
The amp will make it a 1 ohm final load because that is what you'll be presenting to it by wiring all positive coils to + on amp and all negatives to - on amp. Make sense?
Your amp output terminals are linked internally, they are just double output so you can connect more wires easier.
Connect all positive sub terminals to ANY positve terminal on the amplifier (splitting them up is more efficient)
Connect all negative sub terminals to ANY negative terminal on the amplifier (splitting them up is more efficient)
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
