DC Sound Lab
2 DC 5k, 4 DC Level 4's
You did something wrong then. No way that a pair of strapped 5ks(strapped at 1.4 or .7 per amp) rising to 2.86 ohms(1.43 ohm per amp), with voltage drop down to 12.5v are only putting out 3490w.
With that voltage and reactive ohm load, you should see close to 5k per amp with no issue at all.
Either your settings are wrong, it didnt get burped at full tilt, or you did not do the clamp test properly.
Sounds like ur strapped but the rca isnt connected on the slave so you only clamping once amp
I got thoes exact same numbers with my 5ks then I plugged the strapped rca in and bam, 3500rms per amp.....
Make sure they are actually strapped.....
or try unstrapping them
2 5ks should be more than enough power for 4 lvl 4s, if u were getting upwards of 6k+ after rise ur subs will prolly get warm fast... just to much power for lvl 4s imot
But someone said it before more batteries too!
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
  • Who's Online   1 Member, 0 Anonymous, 615 Guests (See full list)
