It is true, in a perfect world with zero voltage drop, and zero impedance rise sure you will get 2250 out of it, probably more
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
What kind of electrical are you thinking about running if .5 ohm is what you're thinking. If I were you, I'd be smart and either get dual 1s or dual 4s and run and 1 ohm. Don't buy dual 2s and run .5 ohm. You starve that amp for voltage because your charging system can't put out the current for half ohm, and poof goes the amp(and other components potentially).
The BC is a great amp, but just let it do it's work at 1 ohm. Unless you are seriously prepared to back up your electrical to run .5 ohms. To me, 250 watts isn't worth it to go from 1 ohm to .5.
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
