Quick question on tuning an amp with the DD-1
K, so first I tuned my sub amp with the 40Hz -5DB track, was fine. ACV was 28.22, and 28.8 is 400 watts@ 2 ohms, so just shy of 400 watts. Now I tuned it with the -10 track, and the ACV is at 40, so does that mean it is putting out 800 watts at 2 ohms? with that said, it is WAY TO MUCH, and I bottom out a lot. So would I be fine, with still using the -10 track, but setting it down to 34.5 ACV, which is just short of 600 watts? Also, all this tuning was done with the DD-1, and will be done using the DD-1. Would I be fine doing what I just asked as long as the DD-1 doesn't have the distortion light come on?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
What tone are you playing to check voltage after you set wit the -10db tone?
That being said I guess not to use the -10. Which tone should i use?
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Use whatever tone you set with. Here is te thing, you have to watch voltage when playing tones at full tilt. If you set gains with the car off then you set with the amplifier getting around 13v. If you go below that voltage you can clip. But i don't know why you are getting more output with with different tones.
I would suggest something but from my reading none of my experance matters i would just be guessing so good luck with that
Ok then
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I tuned with the car on floating from 14.3-14.4, I watch my voltage and never try to drop below 13. The reason you get different output is because the tones are different from a -5, -10 and -15 DB.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I'm confused. How do you get 28V with the -5db and then 40V with -10db?
AC Voltage
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
You are wrong, if you set the amp gain with -5, then played -5 your output should be the same as if you set with -10 and played -10. Are you sure you didn't set with -10 and play the 0db track?
  • Who's Online   0 Members, 0 Anonymous, 1575 Guests (See full list)
