Jordan Guess Posted August 21, 2012 Report Share Posted August 21, 2012 after choosing # of ports and port diameter, for port length am i calculating the sum of all ports used, or the length of each port? and then after that for length of external port, is it summed length of all ports extending out of the box or is it for each? Link to comment Share on other sites More sharing options...
Joe X Posted August 21, 2012 Report Share Posted August 21, 2012 The length is for each. Link to comment Share on other sites More sharing options...
Jordan Guess Posted August 21, 2012 Author Report Share Posted August 21, 2012 so when im fooling with the length to adjust what frequency i want, im only messing with the length of one port? or would it be for every inch i adjust, its actually 2 inches? Link to comment Share on other sites More sharing options...
Joe X Posted August 21, 2012 Report Share Posted August 21, 2012 When you select two ports for example and you change the length you are actually changing the length of both, not only that but the displacement of the increment/decrement will be that of both also. Link to comment Share on other sites More sharing options...
