I have an 05 cavalier walled with 4 15s and the resonate fz peaks at 53hz and the box is tuned to 34hz is there a way to lower the resonate fz or should i match the walls fz to the car? I want the car mostly for demos and hair tricks would b nice to.
http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3
If you peak at 53, raising the tuning would increase your SPL scores, but if you play a lot of music for demos, I would stick with the 34 Hz tuning if it was my system.
Current system:
Previous systems:
i have a question then on this topic. how would you go about lowering your cars peak? if you add deadner does that lower the peak or make it rise?
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
will deadner affect the peak?
I read mix review on it....
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
tipically deadner usually lowers it, if so, might as well deadner the whole area but it may only drop like 5hz tops.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
if deadner changes peak and it could it will raise the res freq
what does deadner do stop or make stuff move less now think of you subs when you play a low note what do the subs do move a lot and slow kinda like your panels do with out deadner
now play 50 hz what do your subs do now move way less and faster like a panle with deadner on it
thats a dumbed down way of explaining it
  • Who's Online   0 Members, 0 Anonymous, 3763 Guests (See full list)
