Relyks Posted August 21, 2012 Report Posted August 21, 2012 Okay this is my first truck and i can tell engine has taking beating over the years so i decided i wanted to do some upgrades now note that i only make 300 on average weekly but really this truck is my only bill for now. so overtime this is what i wanna do. Rebuild http://www.lceperformance.com/Produc...10006&CartID=1 Cooling http://www.lceperformance.com/Produc...93063&CartID=4 http://www.lceperformance.com/Produc...93131&CartID=5 http://www.lceperformance.com/Produc...93018&CartID=3 http://www.lceperformance.com/Produc...32070&CartID=6 then add a little performance to it. http://www.lceperformance.com/Produc...61508&CartID=8 http://www.lceperformance.com/Produc...41030&CartID=7 http://www.lceperformance.com/Produc...42000&CartID=2 now is there anything i should know expect to walk into or need when rebuilding this truck? it is a 1991 toyota 22re with no rebuild ever 180k+ Miles ( speedometer/odometer cable was ripped when i got it ) i know the timing chain is bad and i think the valves need to be adjusted. but does this all seem okay to do? will i see a big difference? any experience with this field? anything would be nice to hear advice , idea's , suggestions and experience's --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
b-dubs89 Posted August 22, 2012 Report Posted August 22, 2012 spend some money at the machine shop haveing your block and head machined and the rotating assembly balanced . best advice i can give .
Dman1320 Posted August 22, 2012 Report Posted August 22, 2012 agree with b-dubs, get the rotating assembly balanced, heads cleaned up and a valve job, and see if the cylinders need a hone. other than that you really have about everything.
Dman1320 Posted August 22, 2012 Report Posted August 22, 2012 oh and check out the lifters and camshaft, since it looks like they dont come with that kit. dont want to rebuild a motor with worn out lobes or junk lifters.
79Bronco Posted August 30, 2012 Report Posted August 30, 2012 22re? No sense is dumping money into rebuilding something that isnt broken. Fix the timing chain. Let it run til it explodes. I've seen tons of these motors go 300-400k+ like its no big deal. It's one of the few yota motors I actually have some respect for :Thumbup: Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
